Zum Hauptinhalt wechseln
Insignia NS-DS9PDVD15 Disc Reader Replacement
Was du brauchst
  1. Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Insignia NS-DS9PDVD15 Disc Reader Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Turn the power off. Slide the power button to OFF.
  2. Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 2, Bild 1 von 2 Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 2, Bild 2 von 2
    • Unplug AC adapter from car cigarette lighter.
  3. Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 3, Bild 1 von 1
    • Make sure there is no DVD or CD in the disc tray
  4. Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 4, Bild 1 von 2 Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 4, Bild 2 von 2
    • Unscrew the nine 9mm screws with a JIS #000 screwdriver.
  5. Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 5, Bild 1 von 3 Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 5, Bild 2 von 3 Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 5, Bild 3 von 3
    • Pry off back panel with prying tool, then remove by hand.
  6. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: Schritt 6, Bild 1 von 2 Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Tray: Schritt 6, Bild 2 von 2
    • After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
    • Unscrew them with the JIS #000 screwdriver.
  7. Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 7, Bild 1 von 1
    • Slide the tray up and off of the hinge completely.
  8. Insignia NS-DS9PDVD15 Disc Reader Replacement, Disc Reader: Schritt 8, Bild 1 von 1
    • Locate the disk reader, it will be right under the disk chamber.
  9. Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 9, Bild 1 von 1
    • Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
  10. Insignia NS-DS9PDVD15 Disc Reader Replacement: Schritt 10, Bild 1 von 1
    • Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 580
