Was du brauchst
After the back is removed and the disk tray is loose from the bottom, locate the two, 3 mm screws that hold the tray to the hinge.
Unscrew them with the JIS #000 screwdriver.
Pick it straight up, it should slide off the three pegs holding it in place, if not, wiggle each peg individually.
Once you have it loose, unplug it from the PC Board. Then the disk reader can be removed.
Fast fertig!
Abschluss
