Einleitung
A fuse is a device that protects the electrical circuitry of your fan and power source. Fuses have a small wire inside them that will melt and disrupt the electrical current if there is a surge of electricity. A blown or damage fuse will prevent any power distribution to your fan.
Was du brauchst
Grasp the plug firmly and slide the fuse access cover toward the end of the plug prongs with a Flat-head screwdriver.
Carefully pry the 5A fuse out of the plug by slipping the Flat-head screwdriver under one side of the fuse and popping the fuse upward.
Eine weitere Person hat diese Anleitung absolviert.
