Zum Hauptinhalt wechseln
Insignia NS-F12R6-SS Motor Housing Replacing
Was du brauchst
  1. Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: Schritt 1, Bild 1 von 2 Insignia NS-F12R6-SS Motor Housing Replacing, Front Cage: Schritt 1, Bild 2 von 2
    • Unplug your fan.
    • Remove the 20 mm bolt that fastens the fan ring located at the bottom of the fan cage with a Phillips #3 screwdriver.
  2. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 2, Bild 1 von 1
    • Remove the ring that runs around the edge of the fan cage.
  3. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 3, Bild 1 von 1
    • Remove the front of the fan cage.
  4. Insignia NS-F12R6-SS Motor Housing Replacing, Fan Blade: Schritt 4, Bild 1 von 1
    • Remove the 8 mm bolt fastening the fan blades to the rotor with a Phillip #3 screwdriver.
  5. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 5, Bild 1 von 1
    • Take caution when removing the fan blades. They can be sharp!
    • Slide the fan blade off the end of the rotor.
  6. Insignia NS-F12R6-SS Motor Housing Replacing, Back Cage: Schritt 6, Bild 1 von 1
    • Unscrew the four 8 mm bolts that fasten the back of the fan cage back to the motor housing with a Phillips #3 screwdriver.
  7. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 7, Bild 1 von 1
    • Pull the back cage off.
  8. Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: Schritt 8, Bild 1 von 2 Insignia NS-F12R6-SS Motor Housing Replacing, Oscillation Button: Schritt 8, Bild 2 von 2
    • Unscrew the 10 mm screw in the center hole of the oscillation knob with a Phillips #3 screwdriver.
  9. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 9, Bild 1 von 1
    • Remove the oscillation knob.
  10. Insignia NS-F12R6-SS Motor Housing Replacing, Motor Housing: Schritt 10, Bild 1 von 1
    • Use your fingers to gently pull the power knob directly away from the motor housing.
  11. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 11, Bild 1 von 1
    • Unscrew the flat 17 mm nut fastened at the bottom of the power knob with a small crescent wrench.
  12. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 12, Bild 1 von 2 Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 12, Bild 2 von 2
    • Remove the four 6 mm bolts and small washers that secure the front face of the motor housing with a Phillips #3 screwdriver and remove the washers.
  13. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 13, Bild 1 von 1
    • Pull the front face of the motor housing off toward the front of the rotor.
  14. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 14, Bild 1 von 2 Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 14, Bild 2 von 2
    • Remove the 10 mm triangular-headed bolt with a Phillips #3 screwdriver.
  15. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 15, Bild 1 von 1
    • Slide the back end of the motor housing away from the front of the rotor.
  16. Insignia NS-F12R6-SS Motor Housing Replacing: Schritt 16, Bild 1 von 1
    • Remove the small piece of paper hanging on the power button.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Hank
1.091 Reputation
8 Anleitungen geschrieben
CSU Fullerton, Team S2-G1, Bruce Fall 2018 Mitglied von CSU Fullerton, Team S2-G1, Bruce Fall 2018
CSUF-BRUCE-F18S2G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 1,558
