Einleitung
Because the antenna is an external component of the device, it can easily be broken and will need replacing. You must remove the rear panel first before replacing the antenna.
Was du brauchst
Be sure the radio is turned off by pressing the red power button.
Or, if using the charger, remove the power cord.
Remove the panel on the back side of the radio by pressing the arrow in a downward motion.
Remove the batteries one-by-one by pulling from the positive terminal of the top left battery.
Remove the adjacent battery by simply pulling it out of the holder.
Repeat for the bottom row of batteries.
Using the J1 Philip's head screwdriver, remove the 4 screws from the back side of the radio.
Using the metal spudger, pry open the panel with the metal spudger. Work you way around the whole device.
Using the J1 Philip's head screwdriver, unscrew the bolt attaching the antenna to the back panel.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
