Zum Hauptinhalt wechseln
Insignia NS-HDRAD Antenna Replacement
Was du brauchst
  1. Insignia NS-HDRAD Antenna Replacement, Battery: Schritt 1, Bild 1 von 2 Insignia NS-HDRAD Antenna Replacement, Battery: Schritt 1, Bild 2 von 2
    • Be sure the radio is turned off by pressing the red power button.
    • Or, if using the charger, remove the power cord.
  2. Insignia NS-HDRAD Antenna Replacement: Schritt 2, Bild 1 von 3 Insignia NS-HDRAD Antenna Replacement: Schritt 2, Bild 2 von 3 Insignia NS-HDRAD Antenna Replacement: Schritt 2, Bild 3 von 3
    • Remove the panel on the back side of the radio by pressing the arrow in a downward motion.
  3. Insignia NS-HDRAD Antenna Replacement: Schritt 3, Bild 1 von 3 Insignia NS-HDRAD Antenna Replacement: Schritt 3, Bild 2 von 3 Insignia NS-HDRAD Antenna Replacement: Schritt 3, Bild 3 von 3
    • Remove the batteries one-by-one by pulling from the positive terminal of the top left battery.
    • The battery's positive terminal is indicated by a "+" on the side.
    • Remove the adjacent battery by simply pulling it out of the holder.
    • Repeat for the bottom row of batteries.
  4. Insignia NS-HDRAD Antenna Replacement, Rear Panel: Schritt 4, Bild 1 von 2 Insignia NS-HDRAD Antenna Replacement, Rear Panel: Schritt 4, Bild 2 von 2
    • Using the J1 Philip's head screwdriver, remove the 4 screws from the back side of the radio.
    • The 2 bottom screws are difficult to remove. Once unscrewed, either use a spudger to pull it out or knock on the front side of the radio to pop it out.
  5. Insignia NS-HDRAD Antenna Replacement: Schritt 5, Bild 1 von 3 Insignia NS-HDRAD Antenna Replacement: Schritt 5, Bild 2 von 3 Insignia NS-HDRAD Antenna Replacement: Schritt 5, Bild 3 von 3
    • Using the metal spudger, pry open the panel with the metal spudger. Work you way around the whole device.
    • The headphone jack is flush with the paneling so the panel must be moved away from the jack completely to remove.
    • When reassembling, the ports don't fit into their respective holes in the back panel. Use the sharp metal end of the spudger and pull the ports to their slots.
  6. Insignia NS-HDRAD Antenna Replacement: Schritt 6, Bild 1 von 1
    • Using the pliers, separate the wire connector above the left speaker.
    • If this is the first time removing the wire connector, there may be glue holding the wires flush against the panel. Remove this glue with a finger or the plastic spudger.
    • Using regular pliers or needle nose pliers are fine for this tasks. They are interchangeable.
  7. Insignia NS-HDRAD Antenna Replacement: Schritt 7, Bild 1 von 1
    • Using the J1 Philip's head screwdriver, unscrew the bolt attaching the antenna to the back panel.
  8. Insignia NS-HDRAD Antenna Replacement, Antenna: Schritt 8, Bild 1 von 1
    • Remove the antenna and the antenna wire terminal.
    • For reassembly, the wire terminal should fit between the fin with the screw hole and the antenna screw hole.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Baylor, Team 4-3, Williams Fall 2015 Mitglied von Baylor, Team 4-3, Williams Fall 2015
BU-WILLIAMS-F15S4G3
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 12
Insgesamt: 795
