Einleitung
This guide will help you replace a broken or damaged power button on the outside of the Insignia NS-HTMC01-B ceramic heater. A broken or damaged power button can prevent your heater from shutting off, or turning on.
Was du brauchst
Flip your device over so the bottom panel faces you. You should see a hole containing a screw in each corner of the device.
Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
Using a Phillips #1 screwdriver, unscrew the two 7 millimeter screws attaching the power switch to the power button.
Find the clips holding the power button in place.
Press down on the clips to remove the button.
