Zum Hauptinhalt wechseln
Insignia NS-HTMC01-B Power Button Replacement
Was du brauchst
  1. Insignia NS-HTMC01-B Power Button Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Flip your device over so the bottom panel faces you. You should see a hole containing a screw in each corner of the device.
    • Insert a 4-inch Phillips #1 screwdriver into each hole until connected with the 20 millimeter, sharp-point screw.
  2. Insignia NS-HTMC01-B Power Button Replacement: Schritt 2, Bild 1 von 1
    • Find the power switch, located inside the heater on the bottom left corner.
  3. Insignia NS-HTMC01-B Power Button Replacement: Schritt 3, Bild 1 von 1
    • Using a Phillips #1 screwdriver, unscrew the two 7 millimeter screws attaching the power switch to the power button.
  4. Insignia NS-HTMC01-B Power Button Replacement: Schritt 4, Bild 1 von 2 Insignia NS-HTMC01-B Power Button Replacement: Schritt 4, Bild 2 von 2
    • Find the clips holding the power button in place.
    • Press down on the clips to remove the button.
Abschluss
Jack Casey
231 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 125
