Zum Hauptinhalt wechseln
Insignia NS-HTMC01-B Power Cord Replacement
Was du brauchst
  1. Insignia NS-HTMC01-B Power Cord Replacement, Front Case: Schritt 1, Bild 1 von 3 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: Schritt 1, Bild 2 von 3 Insignia NS-HTMC01-B Power Cord Replacement, Front Case: Schritt 1, Bild 3 von 3
    • Flip the device over so the back panel faces up.
    • Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
    • You may want to use a flashlight during this step, as the screws are hard to see.
    • Make sure to firmly connect your screwdriver with the head of the screw. A loose connection can strip the screw head, making the screws nearly impossible to remove.
  2. Insignia NS-HTMC01-B Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Take the screws out and set them aside.
    • Be sure to set them somewhere flat, so they don't roll away.
    • Gently pull the front panel and back panel apart to open the device.
  3. Insignia NS-HTMC01-B Power Cord Replacement, Power Cord: Schritt 3, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the two 1.7mm screws from the white triangular piece covering the power cord.
  4. Insignia NS-HTMC01-B Power Cord Replacement: Schritt 4, Bild 1 von 1
    • Disconnect all of the blue wires. There should be 3 separate blue-wire connections.
  5. Insignia NS-HTMC01-B Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the second black wire from the rectangular piece above the Tip-Over Safety Switch.
    • Remove power cord.
Abschluss
Rebecca Nunez
201 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 189
