Einleitung
Replace the power indicator light of your Insignia NS-HTMC01-B heater.
Was du brauchst
Flip the device over so the back panel faces up.
Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
Take the screws out and set them aside.
Gently pull the front panel and back panel apart to open the device.
Locate the bottom left corner below the fan inside of the heater.
There is a small black rectangular box with two cables coming out of it.
Using a Phillips #4 screwdriver, unscrew the two screws at the base counterclockwise, and set the screws to the side.
After unscrewing the black rectangular box up from the base of the grey frame, locate the small green rectangular light fixture.
Unscrew the one screw from the green rectangle counter clockwise, and set the screw to the side.
Gently lift the green circuit board out of the socket by pulling on the black and white cables.
To replace the LED, unplug the white jack with the black and white cords from the bigger tan circuit board.
Remove the LED cord.
