Einleitung
This guide will take you through the process of replacing the Tip-Over Safety Switch inside the Insignia NS-HTMC01-B.
Was du brauchst
Flip the device over so the back panel faces up.
Unscrew the four screws counter-clockwise from the back panel using a 4mm Phillips screwdriver.
Take the screws out and set them aside.
Gently pull the front panel and back panel apart to open the device.
Use a Phillips #0 screwdriver to remove the 1.3mm screw on the black rectangle above the Tip-Over Safety Switch.
Use a Phillips #2 screwdriver to remove the 0.9mm screw from the back panel of the Tip-Over Safety Switch.
Remove the back panel and the Tip-Over Safety Switch.
