Zum Hauptinhalt wechseln
Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement
Was du brauchst
  1. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the rubber sleeve.
  2. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 2, Bild 1 von 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 2, Bild 2 von 2
    • Use the specified screwdriver to unscrew the ten screws on the back cover.
  3. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 3, Bild 1 von 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 3, Bild 2 von 2
    • Remove the back cover. Be careful to not lose any of the screws because they are extremely small and can be easily lost.
  4. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 4, Bild 1 von 2 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 4, Bild 2 von 2
    • The battery will be attached to the back cover with sticky tape. Unplug the wires connecting the battery to the speaker.
    • Using one of the four blue opening tools, pry the battery off of the back cover.
  5. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 6, Bild 1 von 1
    • Stick the new battery to the back cover using sticky tape.
  6. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 7, Bild 1 von 1
    • Connect the wire from the new battery to the bluetooth speaker.
  7. Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 8, Bild 1 von 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 8, Bild 2 von 3 Insignia NS-SPBTBRICK-CM Back Cover and Battery Replacement: Schritt 8, Bild 3 von 3
    • Place cover back on and using the iFixit screwdriver PH000, screw the ten screws back onto the back cover.
Abschluss
Erin Steele
649 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S5-G2, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S5-G2, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G2
2 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 293
