Einleitung
Make sure the device is powered off before you start following the instructions. If you have a physical disability with your hand, wrist, or arm consider having a different individual help you because the tasks require steady hands. Be sure to work on a flat surface and to not lose any of the small parts because they are very small and can be lost easily.
Was du brauchst
Remove the back cover. Be careful to not lose any of the screws because they are extremely small and can be easily lost.
The battery will be attached to the back cover with sticky tape. Unplug the wires connecting the battery to the speaker.
Using one of the four blue opening tools, pry the battery off of the back cover.
Place cover back on and using the iFixit screwdriver PH000, screw the ten screws back onto the back cover.
