Einleitung
This guide gives an in depth explanation of replacing the bluetooth button in the Insignia Bluetooth Speaker. If you have any physical disability in your hand, wrist, or arm please consider having a different individual because these tasks require steady hands.
Was du brauchst
After successfully removing the plastic cover, use a sauter against the bluetooth button. The heat will make the removal of the button easy.
Place the new bluetooth button in the place of the old bluetooth button and mend the button into place using heat.
