Zum Hauptinhalt wechseln
Einleitung
If your Speaker is experiencing poor sound quality or distortion it may be time to replace the speaker components. Note that if you do not wish to purchase new speaker components removing a single one may fix the sound quality issues.
  1. Run your hand around the device where the sleeve connects, lifting lightly up until the edges detach from the device case. Run your hand around the device where the sleeve connects, lifting lightly up until the edges detach from the device case.
    • Run your hand around the device where the sleeve connects, lifting lightly up until the edges detach from the device case.
  2. Turn the device around and gently push the speaker through until it separates from the sleeve. Turn the device around and gently push the speaker through until it separates from the sleeve.
    • Turn the device around and gently push the speaker through until it separates from the sleeve.
  3. Using a Phillips #0 screwdriver, remove the the ten 5.1mm screws that hold down the battery panel on the bottom of the speaker unit. Using a Phillips #0 screwdriver, remove the the ten 5.1mm screws that hold down the battery panel on the bottom of the speaker unit.
    • Using a Phillips #0 screwdriver, remove the the ten 5.1mm screws that hold down the battery panel on the bottom of the speaker unit.
  4. Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel. Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel. Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel.
    • Using your hands, pry the panel off of the top of the device to reveal the device circuit board and the battery attached to the inner side of the panel.
  5. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  6. Using tweezers, carefully detach the battery wire from the circuit board and lift out the panel with the attached battery. Using tweezers, carefully detach the battery wire from the circuit board and lift out the panel with the attached battery.
    • Using tweezers, carefully detach the battery wire from the circuit board and lift out the panel with the attached battery.
  7. Using hands or a spudger, pry the front side of the plastic shielding (side opposite of power, control, and auxiliary port cover) from the device. Using hands or a spudger, pry the front side of the plastic shielding (side opposite of power, control, and auxiliary port cover) from the device. Using hands or a spudger, pry the front side of the plastic shielding (side opposite of power, control, and auxiliary port cover) from the device.
    • Using hands or a spudger, pry the front side of the plastic shielding (side opposite of power, control, and auxiliary port cover) from the device.
  8. Lift the front plastic shielding from the device. Lift the front plastic shielding from the device.
    • Lift the front plastic shielding from the device.
  9. Using a Phillips #1 screwdriver, remove the eight 10mm screws on the revealed front panel.
    • Using a Phillips #1 screwdriver, remove the eight 10mm screws on the revealed front panel.
  10. Turn the device around and remove the rear panel from the device to reveal the device’s speaker units. Turn the device around and remove the rear panel from the device to reveal the device’s speaker units.
    • Turn the device around and remove the rear panel from the device to reveal the device’s speaker units.
  11. Remove the speaker brackets of the speaker to be replaced by unscrewing the three 7.5mm screws holding them in place with the Phillips #1 screwdriver. If the brackets do not come out with the screws you may need to pull them out with tweezers. If the brackets do not come out with the screws you may need to pull them out with tweezers.
    • Remove the speaker brackets of the speaker to be replaced by unscrewing the three 7.5mm screws holding them in place with the Phillips #1 screwdriver.
    • If the brackets do not come out with the screws you may need to pull them out with tweezers.
  12. Using tweezers, detach the cord connecting the speaker to the device and lift out the speaker. Using tweezers, detach the cord connecting the speaker to the device and lift out the speaker.
    • Using tweezers, detach the cord connecting the speaker to the device and lift out the speaker.
Abschluss
If desired, repeat steps 10 and 11 to replace the other speaker within the device. Follow the steps of this guide and the battery replacement guide in reverse order to reassemble the device.
Ein weiterer Nutzer hat diese Anleitung absolviert.
ETHAN BRUNHOFER
152 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G6, Harley Spring 2018 Mitglied von IUPUI, Team S2-G6, Harley Spring 2018
IUPUI-HARLEY-S18S2G6
3 Mitglieder
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 84
