Zum Hauptinhalt wechseln
Insignia Sport NS-4V17 Front Case Cover Replacement
Was du brauchst
  1. Insignia Sport NS-4V17 Front Case Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 2, Bild 1 von 2 Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 2, Bild 2 von 2
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 3, Bild 1 von 1
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 4, Bild 1 von 1
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: Schritt 5, Bild 1 von 2 Insignia Sport NS-4V17 Front Case Cover Replacement, Front Case Cover: Schritt 5, Bild 2 von 2
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  6. Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 6, Bild 1 von 1
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  7. Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 7, Bild 1 von 3 Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 7, Bild 2 von 3 Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 7, Bild 3 von 3
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  8. Insignia Sport NS-4V17 Front Case Cover Replacement: Schritt 8, Bild 1 von 1
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Wesley Ballar
88 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 12-36, Amido Spring 2013 Mitglied von Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 347
