Einleitung
Does your case have a crack? Want to clean out some dust or dirt trapped underneath the screen? This guide will help you take the front cover off.
Was du brauchst
Detach the back cover by carefully pulling up and out on the back plastic casing.
Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
Remove the four corner plastic covers on the back of the device using the plastic opening tool.
Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
Carefully wedge the plastic opening tool into either long side of the device.
Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
Repeat these steps on the other side of the device.
Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
