Einleitung
Is your scroll wheel not turning properly? Need to remove it to clean it? This guide will show you how to remove the Scroll Wheel. This simple guide will show you how to do it.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
    • Remove the 3mm Phillips #00 screw on the back of the Insignia NS-4v17.
  2. Detach the back cover by carefully pulling up and out on the back plastic casing. Do not pull apart the red wire connecting the battery to the device.
    • Detach the back cover by carefully pulling up and out on the back plastic casing.
    • Do not pull apart the red wire connecting the battery to the device.
  3. Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Use the plastic opening tool to reach underneath the battery, opposite from the side with the red wire, and remove it from its plastic case.
    • Be careful to not tear the wires while opening the case.
  4. Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Reach under the white plastic wire connector using the plastic opening tool and disconnect it from the socket.
    • Do not disconnect wires from plastic connector.
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  6. Remove the four corner plastic covers on the back of the device using the plastic opening tool. Remove the four corner plastic covers on the back of the device using the plastic opening tool.
    • Remove the four corner plastic covers on the back of the device using the plastic opening tool.
  7. Using a Philips #00 screwdriver remove all four 4.5mm  corner screws located underneath the corner pads.
    • Using a Philips #00 screwdriver remove all four 4.5mm corner screws located underneath the corner pads.
  8. Carefully wedge the plastic opening tool into either long side of the device. Slowly move the plastic opening tool along the side of the device, separating the front and back case covers. Repeat these steps on the other side of the device.
    • Carefully wedge the plastic opening tool into either long side of the device.
    • Slowly move the plastic opening tool along the side of the device, separating the front and back case covers.
    • Repeat these steps on the other side of the device.
  9. Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
    • Once the front cover is loose, use your fingers to remove the front case cover for a new installation.
  10. Remove the white plastic ring from around the scroll wheel using your fingers.
    • Remove the white plastic ring from around the scroll wheel using your fingers.
  11. Insert the plastic opening tool underneath any side of the scroll wheel. Slowly lift up on the plastic opening tool and the scroll wheel will come off. Slowly lift up on the plastic opening tool and the scroll wheel will come off.
    • Insert the plastic opening tool underneath any side of the scroll wheel.
    • Slowly lift up on the plastic opening tool and the scroll wheel will come off.
Abschluss
Wesley Ballar
88 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 12-36, Amido Spring 2013 Mitglied von Cal Poly, Team 12-36, Amido Spring 2013
CPSU-AMIDO-S13S12G36
4 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 308
