Einleitung
Once you have the back dissembled, feel free to follow this guide to see how you can replace the battery.
Was du brauchst
Turn the laptop upside down with the logo facing the surface of the table.
Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
Unscrew two 8mm screws with a Phillips #0 screwdriver.
Unscrew one silver, wide-head, 8mm screw with a Phillips #0 screwdriver.
Disconnect the battery cable from the motherboard.
To remove the old battery, lift from the bottom and pull the battery towards you.
To reassemble your device, follow these instructions in reverse order using a new battery.
2 weitere Personen haben diese Anleitung absolviert.
