Zum Hauptinhalt wechseln
Inspiron 7359 2-in-1 Hard Disk Drive Replacement
Was du brauchst
  1. Inspiron 7359 2-in-1 Hard Disk Drive Replacement, Bottom Case: Schritt 1, Bild 1 von 1
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: Schritt 2, Bild 1 von 2 Inspiron 7359 2-in-1 Hard Disk Drive Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  4. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: Schritt 4, Bild 1 von 1
    • All hardware components should be exposed.
  5. Inspiron 7359 2-in-1 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 5, Bild 1 von 1
    • Unscrew three 3mm screws with a Phillips #0 screwdriver and remove them.
    • These screws hold the hdd and removing these screws will make it easier to remove it.
  6. Inspiron 7359 2-in-1 Hard Disk Drive Replacement: Schritt 6, Bild 1 von 2 Inspiron 7359 2-in-1 Hard Disk Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift the hard drive from the left side. Be careful not pull on it.
    • Pull the SATA cable that's connect to the hard drive and then carefully place the cable on the side.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Gateway, Team S1-G3, Saknee Fall 2019 Mitglied von Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 27
Letzte 30 Tage: 31
Insgesamt: 215
