Einleitung
The Dell Inspiron 13 7359 2-in-1 is an excellent computer with Wi-Fi 802.11ac 1×1 (Wi-Fi 5). Consider changing your WiFi card if:
- The computer is disconnecting from the WiFi frequently, even if you're close to the router.
- The WiFi is consistently slow, even when other devices on the same network are working fine.
- The computer isn't finding any WiFi networks or isn't connecting to any known networks.
- The WiFi strength is consistently weak or nonexistent, even when you're close to the router.
- You're getting error messages related to your WiFi router.
If you have determined that there's no other possible reason why your computer shouldn't be working, even after updates and connecting to other networks and making sure the router's not the problem, it might be a safe bet to replace the WiFi card. The WiFi card is not dangerous on its own, even if it's connected to a power source. Make sure to power off and disconnect the computer when you start taking your computer apart. You won't need more than the actual replacement WiFi card and a few tools to disassemble the computer, so follow this guide and keep your connection running smoothly.
Was du brauchst
Turn the laptop upside down with the logo facing the surface of the table.
Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
Use the spudger tool to remove the two antenna cables.
Remove the black screw.
Slightly pull up the end and remove the WiFi card. Be careful not to damage the internal adapter.
Eine weitere Person hat diese Anleitung absolviert.
