Zum Hauptinhalt wechseln
Install Series 2 Display on a Series 3 with Apple Pay
Was du brauchst
  1. Install Series 2 Display on a Series 3 with Apple Pay, Meet the patient: Schritt 1, Bild 1 von 1
    • Here we have a Series 3 Apple Watch with a broken Display.
    • Sad.
  2. Install Series 2 Display on a Series 3 with Apple Pay, Open 'er up: Schritt 2, Bild 1 von 1
    • Remove the broken Display. The worse they're busted up, the easier they come off!
    • Remove any adhesive residue and tape from the Force Touch Sensor, and inspect it for damage. Replace if necessary.
  3. Install Series 2 Display on a Series 3 with Apple Pay, Prepare the donor: Schritt 3, Bild 1 von 1
    • The right-hand module contains the NFC and Light Sensor. It's attached by some adhesive dots, two solder bumps (for the NFC antenna connection), and some copper tape.
    • Cut the copper tape from the NFC module.
  4. Install Series 2 Display on a Series 3 with Apple Pay, Save the NFC, save the world: Schritt 4, Bild 1 von 3 Install Series 2 Display on a Series 3 with Apple Pay, Save the NFC, save the world: Schritt 4, Bild 2 von 3 Install Series 2 Display on a Series 3 with Apple Pay, Save the NFC, save the world: Schritt 4, Bild 3 von 3
    • Using an Xacto #17 blade, chisel the NFC module from the damaged Display.
    • Keep the blade as parallel as possible to the Display.
  5. Install Series 2 Display on a Series 3 with Apple Pay, Successful donation: Schritt 5, Bild 1 von 3 Install Series 2 Display on a Series 3 with Apple Pay, Successful donation: Schritt 5, Bild 2 von 3 Install Series 2 Display on a Series 3 with Apple Pay, Successful donation: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Now the NFC module is free. There's some tape on the back of the module; you can peel it off with tweezers.
    • You can see there are two solder bumps under here. These are the connections to the NFC antenna.
    • If you use alcohol or some other solvent to help clean up, use it very sparingly. We don't want to mess up the Light Sensor.
  6. Install Series 2 Display on a Series 3 with Apple Pay, Meet the New Guy: Schritt 6, Bild 1 von 2 Install Series 2 Display on a Series 3 with Apple Pay, Meet the New Guy: Schritt 6, Bild 2 von 2
    • Here is a "new" (probably harvested) Series 2 Display I bought online. I marked it with a "2" just because.
    • Remove the NFC module from this display. You can discard it or sprinkle it on your breakfast cereal.
    • I got a little over-aggressive taking this off so you can see I removed some of the black tape covering the NFC antenna. No harm done, though, and it let me show a corner of the NFC antenna.
  7. Install Series 2 Display on a Series 3 with Apple Pay, A sticky situation: Schritt 7, Bild 1 von 1
    • Now we apply a bit of "Z Tape" to the back of the module. Z Tape is nifty stuff that conducts electricity through its thickness but not sideways.
    • In this photo the release layer is still on the Z tape. We'll take it off before sticking the module onto the Series 2 Display.
  8. Install Series 2 Display on a Series 3 with Apple Pay, Frankenstein's Monster: Schritt 8, Bild 1 von 1
    • Yup, that's our Series 2 Display with the NFC module from the broken S3 Display attached. Alignment here is fairly important so don't just slap it on all willy-nilly.
  9. Install Series 2 Display on a Series 3 with Apple Pay, Reprogramming: Schritt 9, Bild 1 von 1
    • Sometimes it just works, and sometimes you need to reflash the OS to make everyone play nice together. Good luck finding the magic IPSW files.
  10. Install Series 2 Display on a Series 3 with Apple Pay, It works!: Schritt 10, Bild 1 von 1
    • After all this, Apple Pay can be configured on the Watch and you can see that it talks to the NXP TagInfo app.
    • I had to use an Android phone to test the NFC because Apple doesn't let apps get deep enough into iPhone's NFC to read this stuff.
Ziellinie
16 weitere Nutzer:innen haben diese Anleitung absolviert.
13 Kommentare
This is one of those guides that goes above and beyond. Now can you tell us how to flash the software?
fdsajky675 - Antwort
viarengo1 - The tricky part of reflashing is actually just getting the IPSW files to flash — OTA update files don’t work and Apple doesn’t release the complete files. If you can manage to get the file, though, you connect the Watch to a programming adapter (either iBus or the Apple adapter), load iTunes, and the Watch shows up. Then you shift-click on Restore, point to your hard-won IPSW, and off you go. You can sometimes find Apple programming adapters on eBay and MFCBox sells the iBus, which is a clone of the Apple adapter. But the IPSW files are a major PITA. Right now I don’t think any of them are in the wild except WatchOS 4.3.1 for Series 3 only.
Gordon Hlavenka - Antwort
There are plenty of ipsws for Apple Watch on ipsw.me. Are they usable?
IO -
IO - No, the ipsws on ipsw.me and similar sites won’t work. They are over-the-air update files (“OTA”) and do not contain a complete set of code including boot loader and all modules.
Can’t you just use this? https://ipsw.me/otas
Peyton Blume - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 97
Insgesamt: 19,849
