Zum Hauptinhalt wechseln
Install macOS Printer Drivers
  1. Install macOS Printer Drivers, Install macOS Printer Drivers: Schritt 1, Bild 1 von 2 Install macOS Printer Drivers, Install macOS Printer Drivers: Schritt 1, Bild 2 von 2
    • Find the driver for your printer brand on the link below:
    • https://support.apple.com/kb/index?page=...
    • Download the driver for your printer, by clicking on the "Download" button.
    • If the message: "This connection is not private" appears, open the page with the private mode of your browser.
  2. Install macOS Printer Drivers: Schritt 2, Bild 1 von 2 Install macOS Printer Drivers: Schritt 2, Bild 2 von 2
    • Open your .dmg file
    • Open your .pkg file
    • If this message appears: "This update requires macOS 12.0 or earlier." click Close and continue with the next step.
    • Otherwise, continue with step 7.
  3. Install macOS Printer Drivers: Schritt 3, Bild 1 von 3 Install macOS Printer Drivers: Schritt 3, Bild 2 von 3 Install macOS Printer Drivers: Schritt 3, Bild 3 von 3
    • Move your .pkg file to your desktop
    • Open Terminal
    • Enter: cd Desktop/ then press the Enter key
  4. Install macOS Printer Drivers: Schritt 4, Bild 1 von 3 Install macOS Printer Drivers: Schritt 4, Bild 2 von 3 Install macOS Printer Drivers: Schritt 4, Bild 3 von 3
    • Enter the following command: pkgutil --expand FileName.pkg FileName
    • Change FileName to the name of your file, in both places.
    • Then press the Enter key.
    • A folder with the file name appears on your desktop.
    • Open the folder.
  5. Install macOS Printer Drivers: Schritt 5, Bild 1 von 2 Install macOS Printer Drivers: Schritt 5, Bild 2 von 2
    • Open the Distribution file with TextEdit
    • Then change the number after (system.compareVersions(system.version.ProductVersion, '12.0')" to that of your macOS version or later.
    • Save the file and close it.
  6. Install macOS Printer Drivers: Schritt 6, Bild 1 von 2 Install macOS Printer Drivers: Schritt 6, Bild 2 von 2
    • Return to the Terminal
    • Enter the following command: pkgutil --flatten FileName FileName.pkg and press the Enter key.
    • Close theTerminal and open FileName.pkg on your desktop.
  7. Install macOS Printer Drivers: Schritt 7, Bild 1 von 1
    • Congratulations, you can proceed with the installation by following the steps one by one.
Abschluss
Congratulations, you made it!
2 weitere Personen haben diese Anleitung absolviert.
fr en
100%
Hier starten ›
Anthony Fassler
6.855 Reputation
4 Anleitungen geschrieben
2 Kommentare zur Anleitung
Merci pour cet excellent tutoriel, j'ai récupéré le fonctionnement de mon ancienne imprimante HP sur mon Mac !
Bravo !!!
Cédric Trocellier - Antwort
Bonjours ,j'ai un ordinateur imac et je veux installer une imprimante canon, je dois telecharger un logiciel pour ça et je n'y arrive pas; pouvez vous m'aider svp; merci
Moh Cho - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 26
Letzte 30 Tage: 122
Insgesamt: 4,204
