Einleitung
This guide will walk you through the steps necessary to patch the elbow of your Patagonia sweater. A piece of felted sweater or corduroy fabric will make a great patch for your sweater. Choose a patch color that compliments the color of your sweater. You can sew the patch on by hand if you don’t have a sewing machine. Whether you hand-sew or machine-sew, you will need a ballpoint needle to prevent any snagging while sewing. If you choose to sew by hand, simply ignore the steps involving the sewing machine. Whichever method you choose, be sure to only sew through the top layer of the sleeve, or else you’ll sew your sleeve shut! New to sewing? Check out our sewing glossary.
Was du brauchst
Lay your sweater flat on a work surface, damage side up.
Measure the length of the hole.
Measure the width of the hole.
On a piece of paper, mark the endpoints of a line that measures the length of the hole, plus one inch.
Mark the center of the two endpoints.
From the center, turn the measuring tape 90 degrees. Mark the endpoints of a line that measures the width of the hole, plus one inch.
Sketch a curve connecting the endpoints of the length and width.
Draw a straight line connecting the endpoints of the width, going though the center point.
Fold the paper in half on the straight line.
Cut along the curved line. The piece you have just cut out will be your pattern.
Lay your pattern over the hole to verify that it is the correct size and shape.
Lay your pattern over the piece of fabric you’ve choosen to use as a patch.
Pin your pattern piece onto your patch fabric.
Using fabric scissors, cut around the pattern piece.
Inspect the patch, going back to clean up any rough edges with scissors.
Slide the sleeve over the arm of your sewing machine, just like you’d put the sleeve over your own arm.
Align the very edge of the patch with the needle.
Sew around the edge of the patch, turning the sleeve as you go.
Sew until you come all the way around, retracing your first stitches.
Slide the sleeve off the arm of your sewing machine.
Clip any loose threads.
Repeat on the other sleeve if you want symmetrical professor patches.
If you need further help, contact Patagonia Customer Service.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
