Zum Hauptinhalt wechseln
Installing the Battery for a bObi Robotic Vacuum
Was du brauchst
  1. Installing the Battery for a bObi Robotic Vacuum, Battery: Schritt 1, Bild 1 von 3 Installing the Battery for a bObi Robotic Vacuum, Battery: Schritt 1, Bild 2 von 3 Installing the Battery for a bObi Robotic Vacuum, Battery: Schritt 1, Bild 3 von 3
    • Use a phillips head screwdriver to remove the two screws holding the battery cover down.
    • Lift the battery cover up.
  2. Installing the Battery for a bObi Robotic Vacuum: Schritt 2, Bild 1 von 3 Installing the Battery for a bObi Robotic Vacuum: Schritt 2, Bild 2 von 3 Installing the Battery for a bObi Robotic Vacuum: Schritt 2, Bild 3 von 3
    • Plug in the battery's circuit plug.
    • Lower the battery into bObi.
    • Tuck the wire into the side of the battery. do not push it underneath the battery itself.
  3. Installing the Battery for a bObi Robotic Vacuum: Schritt 3, Bild 1 von 3 Installing the Battery for a bObi Robotic Vacuum: Schritt 3, Bild 2 von 3 Installing the Battery for a bObi Robotic Vacuum: Schritt 3, Bild 3 von 3
    • When both are lowered into the compartment, replace the battery cover. Ensure it lies flat overtop the battery.
    • Reinstall the two screws to finish assembling bObi's battery.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Chelsea
2.278 Reputation
31 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 666
