Zum Hauptinhalt wechseln
Instant Pot 60 EPC Pressure Sensor Replacement
Was du brauchst
  1. Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: Schritt 1, Bild 1 von 3 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: Schritt 1, Bild 2 von 3 Instant Pot 60 EPC Pressure Sensor Replacement, Pressure Sensor: Schritt 1, Bild 3 von 3
    • Ensure the device is unplugged and cool before beginning.
    • Remove the lid and inner pot from the Instant Pot and turn the body upside down.
    • Remove the single Torx screw.
  2. Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 2, Bild 1 von 2 Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 2, Bild 2 von 2
    • Turn the bottom face counterclockwise and remove it.
  3. Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 3, Bild 1 von 3 Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 3, Bild 2 von 3 Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 3, Bild 3 von 3
    • In order to reach the pressure sensor you'll need to remove the secondary frame.
    • Remove the three Phillips screws securing the frame.
    • Lift the frame, twist and set next to the body. Take care not to damage any of the attached wiring.
    • Locate the sensor. It has been highlighted in the final image.
  4. Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 4, Bild 1 von 2 Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 4, Bild 2 von 2
    • To remove the sensor, unscrew the main screw between the sensor and slide out.
  5. Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 5, Bild 1 von 3 Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 5, Bild 2 von 3 Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 5, Bild 3 von 3
    • To remove the leads connecting the sensor to the motherboard you will need to unclip them.
    • In order to do so, slide the blue covering up to expose the small hole in the lead.
    • Place a SIM card punch into the hole to unsecure the leads and pull them up. If a SIM card punch is not avaliable then a paperclip or earring should suffice.
  6. Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 6, Bild 1 von 2 Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 6, Bild 2 von 2
    • There will be a secondary lead that is black connecting the sensor the the motherboard.
    • In order to remove that lead just squeeze and pull up.
  7. Instant Pot 60 EPC Pressure Sensor Replacement: Schritt 7, Bild 1 von 1
    • Instant Pot does not provide a new sensor with the device, so it will have to be purchased from a secondary source.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Bela Hernandez
926 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 20
Insgesamt: 83
