Zum Hauptinhalt wechseln
Instant Pot Smart-60 Plastic Base Replacement
Was du brauchst
  1. Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: Schritt 1, Bild 1 von 2 Instant Pot Smart-60 Plastic Base Replacement, Plastic Base: Schritt 1, Bild 2 von 2
    • Take off the lid of the Instant Pot. Grasp the handle and rotate the lid counter-clockwise, then lift up to separate the lid from the base.
  2. Instant Pot Smart-60 Plastic Base Replacement: Schritt 2, Bild 1 von 1
    • Take out the inner pot and place it somewhere out of the way.
  3. Instant Pot Smart-60 Plastic Base Replacement: Schritt 3, Bild 1 von 1
    • Flip the Instant Pot over on its top so that the base is facing upward.
  4. Instant Pot Smart-60 Plastic Base Replacement: Schritt 4, Bild 1 von 1
    • Remove the single 12mm Phillips #2 screw holding the base to the device.
  5. Instant Pot Smart-60 Plastic Base Replacement: Schritt 5, Bild 1 von 1
    • Rotate the base counter-clockwise, then gently lift the base off of the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
paola alvarez
534 Reputation
4 Anleitungen geschrieben
Cal Poly, Team S1-G4, Livingston Winter 2018 Mitglied von Cal Poly, Team S1-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G4
4 Mitglieder
6 Anleitungen geschrieben
13 Kommentare
Hi, I would like to know, where can I buy a new plastic base? Thank you
nathaliawed - Antwort
Hello where can I buy the plastic base
Maureen - Antwort
I would like to buy one of these for an 8 Qt model….very hard to source this and terrible customer support as this seems to be a issue for many that burned theirs.
davidghamilton - Antwort
Did you ever find out where you can buy this part.
Thank you. Belinda
Belinda Berka - Antwort
Do you carry the replacement for this. Thanks
khai01 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 6,667
