Zum Hauptinhalt wechseln
Instax Mini 90 Film Cartridge Replacement
Was du brauchst
  1. Instax Mini 90  Film Cartridge Replacement, Film Cartridge: Schritt 1, Bild 1 von 1
    • Turn ON the camera, and flip it over so that the back cover is visible.
  2. Instax Mini 90  Film Cartridge Replacement: Schritt 2, Bild 1 von 3 Instax Mini 90  Film Cartridge Replacement: Schritt 2, Bild 2 von 3 Instax Mini 90  Film Cartridge Replacement: Schritt 2, Bild 3 von 3
    • Unlock the back cover. It should automatically spring open. If there is an old film cartridge loaded in the camera, remove it.
  3. Instax Mini 90  Film Cartridge Replacement: Schritt 3, Bild 1 von 3 Instax Mini 90  Film Cartridge Replacement: Schritt 3, Bild 2 von 3 Instax Mini 90  Film Cartridge Replacement: Schritt 3, Bild 3 von 3
    • Unwrap the new film cartridge, taking care to not touch the film inside. Only handle the film cartridge by its plastic shell.
    • Line up the small, yellow line on the cartridge with the corresponding yellow line inside the camera. The yellow line on the cartridge should be facing up, away from the camera.
  4. Instax Mini 90  Film Cartridge Replacement: Schritt 4, Bild 1 von 2 Instax Mini 90  Film Cartridge Replacement: Schritt 4, Bild 2 von 2
    • Close the back cover. The film covering should eject automatically.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team S2-G1, Nance Spring 2017 Mitglied von USF Tampa, Team S2-G1, Nance Spring 2017
USFT-NANCE-S17S2G1
4 Mitglieder
12 Anleitungen geschrieben
5 Kommentare
Having an issue with the film pack not loading. Have tried resetting, removing battery etc. Any ideas?
Lawrence Cassel - Antwort
Me too! Ive removed battery, replaced with fresh battery, nothing happens! Ive just used it once! Help!!
susan ahrent - Antwort
I’m having the same problem and I’ve tried everything. Someone help! The film simply isn’t being recognized (no blinking E or anything like that).
ap5029 - Antwort
I am not too sure how to fix that, but definitely try contacting Fujifilm, as they know much more about their products and do repairs as well! https://www.fujifilmusa.com/support/Serv...
Elliott Tegan-Tawney - Antwort
I have a fujifilm instax mini evo hybrid black instant camera but it does not detect film. The message of putting a new cartridge keeps popping-up. Do you know what could be the cause?
Herman Saldana - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 21
Letzte 30 Tage: 154
Insgesamt: 21,187
