Einleitung
Intempo Wireless Speaker is a battery-powered inductive speaker that amplifies audio simply by placing the smartphone on top of it, without the need for WiFi, Bluetooth or any form of wired connection. However, the speaker tends to work intermittently with age as it slowly loses its functionality. Hence, we will be documenting the process of disassembling the “Intempo Wireless Speaker.” The circuit board is a crucial component that keeps the Wireless Speaker functional, and we believe a lot of users will find it beneficial if they are able to disassemble the product to access the circuit board without damaging any parts of the speaker, given the help of our teardown experience.
Was du brauchst
Squeeze latch, tilt and remove battery cover to retrieve the batteries.
Unscrew the 5 screws (9 effective threads each) using Phillips 0 head screwdriver.
Unscrew the 3 screws (with 9 effective threads each) using Phillips 1 head screwdriver.
Lift the circuit board out from the main part.
Loosen the glue holding the speaker on the case using the Lever Prybar.
Slide the speaker upwards to detach them.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
