Einleitung
This guide details the steps to take off the button pad of your Inter-tel IP 8660.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
8 mm long
11 mm long
While holding down the motherboard, gently pull the wire harness connecting the speaker to the motherboard until it comes free.
Remove all plastic buttons. (Note: Look at the initial picture for locations of each button set)
Ein weiterer Nutzer hat diese Anleitung absolviert.
