Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide details the steps to take off the rear cover of your Inter-tel IP 8660.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
    • Before disassembling the phone, make sure it is not plugged into power and the handset phone cord is disconnected from the handset jack.
  2. Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out. 8 mm long 11 mm long
    • Unscrew the 9 highlighted screws using a #1 Phillips head screwdriver. You can use a magnetized screwdriver to draw them out.
    • 8 mm long
    • 11 mm long
  3. Lift up the back cover and set it aside.
    • Lift up the back cover and set it aside.
Abschluss
Mariano Bautista
16 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 11-24, Maness Winter 2012 Mitglied von Cal Poly, Team 11-24, Maness Winter 2012
CPSU-MANESS-W12S11G24
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 494
