Ersatzteile
Kein Ersatzteil erforderlich.
Push in the plastic tab that can be seen through cracks in the front left corner using a spudger.
Grab the cover by the front side and pull upwards.
You might encounter some resistance. Pull firmly, but don't yank it.
Tilt the front case down until the pegs detach from the bottom of the case.
Lift up and outward.
There is a white tab connected to the motherboard. Pull it upward by gently rocking it back and forth.
Disconnect the white wires by using tweezers to gently pull the bottom connector toward you.
Disconnect the thin ribbon wire by using tweezers to gently pull the connector at the bottom toward you.
Use a T6 Torx Screwdriver to remove the 1.3 mm screw at the back of the motherboard.
