Einleitung
This step is one of the longest steps to complete yet it is essential in order to replace the body cover. If the Ion Air Pro is unable to be mounted on because the body cover is damaged, the body cover will have to be replaced. Follow these steps carefully on how to remove the body cover.
Was du brauchst
On the other side of the device, lift this black piece of cover that is underneath the cap, on the bottom side of the Ion Air Pro.
Detach the bottom black piece off from the bottom side but do not disconnect it from the wires.
Finally, you can remove the body cover off and replace it with a new one if you have to.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
4 Kommentare
Can you show a photo of the other side (compared to step 8) showing the mounting thread please?
