Zum Hauptinhalt wechseln
Einleitung
If your record/stop switch is not working follow this guide to replace it.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
    • Remove the six screws (3 mm) that secure the lens cover bezel with a #00 Phillips screwdriver.
  2. Remove the blue securing the lens cover. Then simply pull off the lens cover itself. Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
    • Remove the blue securing the lens cover. Then simply pull off the lens cover itself.
  3. Android Fix Kits
    Ein neues Display oder Akku sind nur ein Kit entfernt.
    Jetzt kaufen
    Android Fix Kits
    Jetzt kaufen
  4. Remove black aluminum casing as shown.
    • Remove black aluminum casing as shown.
  5. Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
    • Using a #00 Phillips screwdriver, unscrew the screw securing the record/stop switch.
  6. Remove the record/stop switch. You are then able to replace the switch.
    • Remove the record/stop switch. You are then able to replace the switch.
    • Be careful to not misplace the power button and spring that will no longer be secured when the switch is removed.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Christopher Brandl
670 Reputation
5 Anleitungen geschrieben
UW Stout, Team S6-G2, Ogden Fall 2018 Mitglied von UW Stout, Team S6-G2, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G2
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
Insgesamt: 107
