Zum Hauptinhalt wechseln
Ivation IVWPDC20Y Buttons Replacement
Was du brauchst
  1. Ivation IVWPDC20Y Buttons Replacement, Buttons: Schritt 1, Bild 1 von 1
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Buttons Replacement: Schritt 2, Bild 1 von 1
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Buttons Replacement: Schritt 3, Bild 1 von 1
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
  4. Ivation IVWPDC20Y Buttons Replacement: Schritt 4, Bild 1 von 1
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Buttons Replacement: Schritt 5, Bild 1 von 1
    • Pry off back outer casing using the black spudger or the blue prying tools
  6. Ivation IVWPDC20Y Buttons Replacement: Schritt 6, Bild 1 von 1
  7. Ivation IVWPDC20Y Buttons Replacement: Schritt 7, Bild 1 von 1
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
  8. Ivation IVWPDC20Y Buttons Replacement: Schritt 8, Bild 1 von 1
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
  9. Ivation IVWPDC20Y Buttons Replacement: Schritt 9, Bild 1 von 1
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
  10. Ivation IVWPDC20Y Buttons Replacement: Schritt 10, Bild 1 von 1
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
  11. Ivation IVWPDC20Y Buttons Replacement: Schritt 11, Bild 1 von 1
    • Use the metal prying tool to lift off the cover of the buttons
  12. Ivation IVWPDC20Y Buttons Replacement: Schritt 12, Bild 1 von 1
    • Use the PH00 bit to remove the four screws on the metal plate around the buttons
  13. Ivation IVWPDC20Y Buttons Replacement: Schritt 13, Bild 1 von 1
    • Finally, use the plastic spudger to push buttons out, and then replace them
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alex
228 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-6, Eyestone Spring 2016 Mitglied von USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 370
