Einleitung
This guide will show you how to replace a faulty lens unit for this camera.
Was du brauchst
With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
Apply a plastic opening tool to each of the corners and gently remove the casing
Remove the five silver screws from the inner casing using the PH00 screwdriver bit
Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
Carefully remove the screen from the silver casing using a prying tool or the black spudger
Using the poker end of the spudger push gently on the black pegs holding the orange tape in place
Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver
Remove the two screws holding the lens assembly to the motherboard using the PH00 bit screwdriver
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
