Zum Hauptinhalt wechseln
JBL Charge 4 Passive Bass Radiators Replacement
Was du brauchst
  1. JBL Charge 4 Passive Bass Radiators Replacement, Speaker Grill: Schritt 1, Bild 1 von 1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Passive Bass Radiators Replacement: Schritt 2, Bild 1 von 2 JBL Charge 4 Passive Bass Radiators Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Passive Bass Radiators Replacement: Schritt 3, Bild 1 von 1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: Schritt 4, Bild 1 von 2 JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: Schritt 4, Bild 2 von 2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Passive Bass Radiators Replacement: Schritt 5, Bild 1 von 2 JBL Charge 4 Passive Bass Radiators Replacement: Schritt 5, Bild 2 von 2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Zachary Colwell
1.914 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G1, White Winter 2019 Mitglied von Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Mitglieder
26 Anleitungen geschrieben
5 Kommentare
Exactly where are supposed to get parts for this, do you suppose !?
Yash Bhushan - Antwort
It says it on the top of the introduction
Jacob Galeano Garcia -
Hi do you hany any suggestion on where to buy the passive radiators?
Epolu Isaac Tushabe - Antwort
Were can i get the main cover from can you help please and the subwoofers
Nate Millette - Antwort
Yo tengo la charge 4 y se me rompió uno de los radiadores lo que yo quisiera saber si se pueden arreglar o lo tengo que cambiar por otro
Reynaldo Ronquillo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 19
Letzte 30 Tage: 70
Insgesamt: 6,819
