Zum Hauptinhalt wechseln
Einleitung
If the grille of your JBL Charge 4 has been damaged and you want to replace it or if you need to get into your device for further repair this guide will show you how. The only tools required are a plastic opening tool and a Phillips #0 screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. Remove the two 8mm Phillips #0 screws from the other edge of the grille. Remove the two 8mm Phillips #0 screws from the other edge of the grille.
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. Pull apart both sides of the grille.
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
Abschluss
Zachary Colwell
1.290 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S1-G1, White Winter 2019 Mitglied von Cal Poly, Team S1-G1, White Winter 2019
CPSU-WHITE-W19S1G1
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 43
