Zum Hauptinhalt wechseln
JBL Clip 2 Speaker Replacement
Was du brauchst
  1. JBL Clip 2 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: Schritt 2, Bild 1 von 1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: Schritt 3, Bild 1 von 1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: Schritt 4, Bild 1 von 1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Michael Hong
1.014 Reputation
5 Anleitungen geschrieben
UW Tacoma, Team 2-2, Rose Winter 2017 Mitglied von UW Tacoma, Team 2-2, Rose Winter 2017
UWT-ROSE-W17S2G2
4 Mitglieder
7 Anleitungen geschrieben
6 Kommentare
If no parts are required what are you replacing the speaker with?
Tom - Antwort
Tom is right you know!
edward felix - Antwort
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - Antwort
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - Antwort
Hi, where I can buy the speaker please? Thank you.
Govan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 56
Insgesamt: 6,485
