Einleitung
The speaker in the JBL Clip 2 is removable. If the speaker does not work, you will notice that the device will not be able to produce any sound, even if the device is able to turn on. If this is the case the speaker will have to be replaced. The device will be taken apart and the speaker will be removed and replaced.
Was du brauchst
Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
4 weitere Personen haben diese Anleitung absolviert.
6 Kommentare
Tom is right you know!
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
