Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove plastic outer housing using hands or a standard spudger.
    • Remove plastic outer housing using hands or a standard spudger.
  2. Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
    • Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
    • Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
  5. Remove the 3-pin connector from motherboard.
    • Remove the 3-pin connector from motherboard.
Abschluss
9 weitere Nutzer haben diese Anleitung absolviert.
College Student
2.546 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S1-G2, Leahy Spring 2017 Mitglied von USF Tampa, Team S1-G2, Leahy Spring 2017
USFT-LEAHY-S17S1G2
5 Mitglieder
12 Anleitungen geschrieben
where did you source the drivers from?
Rashid Saad Siddiqui - Antwort
hi my flip 3 1 speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
manu - Antwort
I too want to know where you can buy new drivers. Can't find them online so far...
Johannes - Antwort
i need help getting the front speakers only where would i get them???
brian ortiz - Antwort
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
Anil Kumar Hembrom - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 6
Letzten 7 Tage: 50
Letzten 30 Tage: 210
Insgesamt: 12,466
