Werkzeuge
Ersatzteile
On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
Remove outermost white casing by gently lifting up on one side.
Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
Gently lift up and remove the silver casing.
Pry the four tabs on each side of the speaker cover (8 tabs total).
Pry the two tabs on each end to remove the cover (4 tabs total).
Slide speaker out of metal speaker cover.
Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
Open the speaker.
22 weitere Nutzer haben diese Anleitung absolviert.
51 Kommentare
I also want to know about the battery specs
https://www.youtube.com/watch?v=apF4qT3e...
Follow this video tutorial. this will help you definitely
danish -
Mine is not working anymore and I suspect that the battery is not charging. I´ve checked the battery and its code is AEC653055-2Pwith rating 3,7V 2000 mAh. It has 3 cables: red, yellow and black. I´ve used a voltage meetering to check if there some charge coming from and it had 4,0 VDC. So, probably the problem related to my device is with the battery, because it´s not charging. Anyone else had this same issue?
hey. i had the same problem with the battery of JBL flip. and i fixed it. Complete video tutorial is here :)
danish -
