Zum Hauptinhalt wechseln
JBL Go Repair Foam Surround Replacement
Was du brauchst
  1. JBL Go Repair Foam Surround Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
  2. JBL Go Repair Foam Surround Replacement: Schritt 2, Bild 1 von 1
    • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
  3. JBL Go Repair Foam Surround Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the loose plastic cover from the speaker.
  4. JBL Go Repair Foam Surround Replacement, Woofer: Schritt 4, Bild 1 von 2 JBL Go Repair Foam Surround Replacement, Woofer: Schritt 4, Bild 2 von 2
    • Once the front cover is removed, use a T6 screwdriver head to remove the four 9 mm screws on the black cover.
  5. JBL Go Repair Foam Surround Replacement: Schritt 5, Bild 1 von 1
    • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
  6. JBL Go Repair Foam Surround Replacement: Schritt 6, Bild 1 von 1
    • Carefully unplug the woofer wires from the motherboard
  7. JBL Go Repair Foam Surround Replacement: Schritt 7, Bild 1 von 1
    • Once the black cover is fully detached from the speaker, unscrew the woofer from the back of the black cover using a T6 screwdriver head.
  8. JBL Go Repair Foam Surround Replacement, Foam Surround: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Once the woofer is removed, use sharp tweezers to carefully remove the foam surround from the woofer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sydney Jason
677 Reputation
4 Anleitungen geschrieben
2 Kommentare
what is the size of the foam surround?
John Darrel Baytan - Antwort
size of foam surround: 1.9"
776831 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 16
Letzte 30 Tage: 92
Insgesamt: 1,610
