Was du brauchst
carefully remove the charging port
be careful of the cables that are still connected to the motherboard.
carefully unplug the old battery from the 6 pin connector on the motherboard
-be extremely careful not to damage the connector.
carefully take the old battery out.
this should be easy if you are doing it correctly.
Eine weitere Person hat diese Anleitung absolviert.
