Zum Hauptinhalt wechseln
Einleitung
To complete this guide, you will need to disassemble your device and use a soldering iron to replace the jack.
  1. Turn the device upside down so that the three rubber pads are facing up.
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Use a heat gun (set to low) to apply heat  to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. Remove the heated rubber pad with a plastic opening tool.
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver. Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. Open the device along its seam. Be careful when separating the device because there are wires connecting the two seperate halves. Be careful when separating the device because there are wires connecting the two seperate halves.
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  7. Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  8. Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device. Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  9. Remove the three 1 cm T-10 Torx screws. Remove the three 1 cm T-10 Torx screws.
    • Remove the three 1 cm T-10 Torx screws.
  10. Carefully press out the white base tube and push up on the circuit board.
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  11. Pull the white wire out of the hot glue. Pull the white wire out of the hot glue.
    • Pull the white wire out of the hot glue.
  12. Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver. Remove the heat sink; it should detach from the bottom of the device. Remove the heat sink; it should detach from the bottom of the device.
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  13. Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board. Turn the device so that the base tube is on top. Remove the base tube by pulling up.
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
  14. Turn the device upside down. Desolder the back lead for the auxiliary port that is circled. Heat the lead until the solder melts.
    • Turn the device upside down.
    • Desolder the back lead for the auxiliary port that is circled.
    • Heat the lead until the solder melts.
    • Remove the solder with the solder pump.
    • For help with soldering view the iFixit soldering guide
  15. Repeat step 13 for the other two leads.
    • Repeat step 13 for the other two leads.
  16. Turn your device right-side up.
    • Turn your device right-side up.
    • Remove the auxiliary jack.
Abschluss
To reassemble your device, replace the auxiliary jack with a new one soldering it in place. Follow these instructions in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Jared Everingham
332 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 9-28, Maness Winter 2014 Mitglied von Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 2,075
