Einleitung
To complete this guide, you will need to disassemble your device and use a soldering iron to replace the jack.
Was du brauchst
Turn the device upside down so that the three rubber pads are facing up.
Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
Remove the heated rubber pad with a plastic opening tool.
Repeat steps 2 and 3 for the two remaining rubber pads.
Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
Remove the heat sink; it should detach from the bottom of the device.
Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
Turn the device so that the base tube is on top.
Remove the base tube by pulling up.
May need to cut the rubber adhesive between the base tube to the circuit board.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
Turn the device upside down.
Desolder the back lead for the auxiliary port that is circled.
Heat the lead until the solder melts.
Remove the solder with the solder pump.
For help with soldering view the iFixit soldering guide
To reassemble your device, replace the auxiliary jack with a new one soldering it in place. Follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
