Zum Hauptinhalt wechseln
JBL On Stage II Power Button Replacement
Was du brauchst
  1. JBL On Stage II Power Button Replacement, Cracking the Case: Schritt 1, Bild 1 von 1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Power Button Replacement: Schritt 2, Bild 1 von 1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Power Button Replacement: Schritt 3, Bild 1 von 1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Power Button Replacement: Schritt 4, Bild 1 von 2 JBL On Stage II Power Button Replacement: Schritt 4, Bild 2 von 2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Power Button Replacement: Schritt 5, Bild 1 von 3 JBL On Stage II Power Button Replacement: Schritt 5, Bild 2 von 3 JBL On Stage II Power Button Replacement: Schritt 5, Bild 3 von 3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Power Button Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Power Button Replacement: Schritt 7, Bild 1 von 2 JBL On Stage II Power Button Replacement: Schritt 7, Bild 2 von 2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II Power Button Replacement, Power Button: Schritt 8, Bild 1 von 2 JBL On Stage II Power Button Replacement, Power Button: Schritt 8, Bild 2 von 2
    • Pull the plastic button off the post.
  9. JBL On Stage II Power Button Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Remove the metal U-clip (compressing the spring) with tweezers.
Abschluss
Cal Poly, Team 9-28, Maness Winter 2014 Mitglied von Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,856
