Zum Hauptinhalt wechseln
JBL Pulse 3 LED Light Display Replacement
Was du brauchst
  1. JBL Pulse 3 LED Light Display Replacement, Speaker Grill: Schritt 1, Bild 1 von 1
    • Lay the JBL Pulse 3 on its side as shown in the picture.
    • Use a plastic opening tool to lift the top right corner of the speaker grill. A small amount of force is necessary to remove the grill.
  2. JBL Pulse 3 LED Light Display Replacement: Schritt 2, Bild 1 von 1
    • Repeat step 1 for bottom right corner of speaker grill.
  3. JBL Pulse 3 LED Light Display Replacement: Schritt 3, Bild 1 von 2 JBL Pulse 3 LED Light Display Replacement: Schritt 3, Bild 2 von 2
    • After pulling the right side of the grill off, place thumb underneath grill as shown in the picture.
    • Lift and pull straight out to pull grill off the posts.
    • Repeat steps 1-3 for the left side of the speaker grill on the JBL Pulse 3. The speaker grill should now be completely removed from the JBL Pulse 3.
  4. JBL Pulse 3 LED Light Display Replacement, Outside Casing: Schritt 5, Bild 1 von 2 JBL Pulse 3 LED Light Display Replacement, Outside Casing: Schritt 5, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the six black 6mm screws on the inside of the top of the bottom section.
  5. JBL Pulse 3 LED Light Display Replacement: Schritt 6, Bild 1 von 2 JBL Pulse 3 LED Light Display Replacement: Schritt 6, Bild 2 von 2
    • Turn the JBL Pulse 3 right-side up and unscrew the top ring of the device. A small amount of force and/or a cotton cloth may be necessary to remove this piece.
  6. JBL Pulse 3 LED Light Display Replacement: Schritt 7, Bild 1 von 2 JBL Pulse 3 LED Light Display Replacement: Schritt 7, Bild 2 von 2
    • Remove the six 5mm screws on top of the JBL Pulse 3 with a Phillips #0 screwdriver.
  7. JBL Pulse 3 LED Light Display Replacement: Schritt 8, Bild 1 von 1
    • Pull off the top disc of the JBL Pulse 3.
  8. JBL Pulse 3 LED Light Display Replacement: Schritt 9, Bild 1 von 2 JBL Pulse 3 LED Light Display Replacement: Schritt 9, Bild 2 von 2
    • Remove the five 7mm screws on the inside of the JBL Pulse 3 with a Phillips #1 screwdriver.
  9. JBL Pulse 3 LED Light Display Replacement: Schritt 10, Bild 1 von 2 JBL Pulse 3 LED Light Display Replacement: Schritt 10, Bild 2 von 2
    • Peel off black, taped-on electrical lead from the inside side of the JBL Pulse 3.
  10. JBL Pulse 3 LED Light Display Replacement: Schritt 11, Bild 1 von 1
    • Pull the top section of the JBL Pulse 3 up. The outside casing to the JBL Pulse 3 should now be removed.
  11. JBL Pulse 3 LED Light Display Replacement, LED Light Display: Schritt 12, Bild 1 von 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: Schritt 12, Bild 2 von 3 JBL Pulse 3 LED Light Display Replacement, LED Light Display: Schritt 12, Bild 3 von 3
    • Use a Phillips #2 screwdriver to remove the six 11 mm screws that circle the bottom of the LED light display.
    • Pull the LED light display off of the JBL Pulse 3 base.
  12. JBL Pulse 3 LED Light Display Replacement: Schritt 13, Bild 1 von 2 JBL Pulse 3 LED Light Display Replacement: Schritt 13, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to pull the five connections off of the LED light display.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Hello,I really need some code to show me how to initialize and LED display and how to output data from it.Any help is much appreciated.
Osama Siddiq - Antwort
Wow jbl
Gyyzhuahyz8yus
Majd Tom - Antwort
Where to buy the leds?
mj.viana1993 - Antwort
Hello i need an assitance in a LED screen manufacturing
volkanoo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 3,119
