Einleitung
An in depth guide on how to replace the motherboard in case of general unresponsiveness or faulty functionality.
Ersatzteile
Keine Ersatzteile angegeben.
Use a plastic opening tool to pry around the edges of the circular rubber panel.
Use your plastic opening tool to pry the button board loose by lifting the edges.
Pull black piece on top of socket away from board to loosen, then detach the cable.
Take out the four 9mm black PH0 screws from the top and bottom of the device.
Pull off cap by hand.
The outer casing can now be removed.
Remove the tape around the cables on the top of the device.
Remove the cables by lifting up on the black bracket and then pulling the cable out.
Remove two black 9mm PH0 screws from outside of inner casing on each side.
Use your metal spudger to unhook the bracket holding the case together.
Pull apart the casing with your hands.
Remove cables by pulling firmly.
Once all of the cables are removed, grip the motherboard and slide it out.
3 weitere Nutzer haben diese Anleitung absolviert.
3 Kommentare
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Hey I need JBL pulse motherboard Where can I buy. Please help
