Zum Hauptinhalt wechseln
JBL Pulse Motherboard Replacement
Was du brauchst
  1. JBL Pulse Motherboard Replacement, Button Board: Schritt 1, Bild 1 von 1
    • Use a plastic opening tool to pry around the edges of the circular rubber panel.
  2. JBL Pulse Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Once the edges are loose, pull off the rubber button panel completely.
    • New adhesive will have to be applied when reassembling.
  3. JBL Pulse Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use your plastic opening tool to pry the button board loose by lifting the edges.
  4. JBL Pulse Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Lift the button board, exposing the attached cable.
  5. JBL Pulse Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Pull black piece on top of socket away from board to loosen, then detach the cable.
  6. JBL Pulse Motherboard Replacement, Outer Casing: Schritt 6, Bild 1 von 3 JBL Pulse Motherboard Replacement, Outer Casing: Schritt 6, Bild 2 von 3 JBL Pulse Motherboard Replacement, Outer Casing: Schritt 6, Bild 3 von 3
    • Take out the four 9mm black PH0 screws from the top and bottom of the device.
    • Pull off cap by hand.
    • The outer casing can now be removed.
  7. JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: Schritt 7, Bild 1 von 2 JBL Pulse Motherboard Replacement, JBL Pulse LED Lights Disassembly: Schritt 7, Bild 2 von 2
    • Remove the tape around the cables on the top of the device.
    • Remove the cables by lifting up on the black bracket and then pulling the cable out.
  8. JBL Pulse Motherboard Replacement, JBL Pulse Disassembly: Schritt 8, Bild 1 von 1
    • Remove two black 9mm PH0 screws from outside of inner casing on each side.
  9. JBL Pulse Motherboard Replacement: Schritt 9, Bild 1 von 3 JBL Pulse Motherboard Replacement: Schritt 9, Bild 2 von 3 JBL Pulse Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Use your metal spudger to unhook the bracket holding the case together.
    • Pull apart the casing with your hands.
  10. JBL Pulse Motherboard Replacement: Schritt 10, Bild 1 von 2 JBL Pulse Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove cables by pulling firmly.
  11. JBL Pulse Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 1
    • Once all of the cables are removed, grip the motherboard and slide it out.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 18-6, Blackwell Fall 2016 Mitglied von USF Tampa, Team 18-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S18G6
3 Mitglieder
8 Anleitungen geschrieben
3 Kommentare
Excelente, funcionó perfectamente la guia. Compré la bateria y el armado funcionó perfecto. Muchas gracias.
Angel Pérez - Antwort
my usb port is damaged. Do I have to replace the whole motherboarD?
dinosdabi - Antwort
Hey I need JBL pulse motherboard Where can I buy. Please help
kashyapvikas228vk1070301 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 9,342
